mrgem
I'm building a 331 stroker -- based on a 66 289 block -- for a project car. The original gearbox ( toploader), bellhouse and flywheel were gone when I bought the car. I found replacements that seemed to work and thought we'd had the problem licked. However...We recently went to install a new starter and the heartburn began.
Seems that Ford, in their infinite wisdom, decided sometime during the 1964 model year to quit using 164-tooth flywheels on small block manual trans cars and replaced it with a thicker, 157-tooth flywheel. The problem came to light when trying to install what O'reilly's listed as a 1965 small block manual trans starter. The starter would not fit into the hole on the sheetmetal blocking plate. The hole was just a tiny bit (less than 1/16") too small. To complicate things even more, there were two starters used for 65 -- A "short nose" and a "long nose" design that not only was dependent on the flywheel (or flex plate) spec and/or the transmission type.
The engine and trans are already installed in the car and I didn't want to pull the engine again or drop the trans. So right now our plan is to to use a dremel tool and open up the starter hole iin the blocking plate - being careful to try and pick up any filings that accumulate in the bellhouse. Does that sound reasonable?
I've attached a bit of info provided by Bob Mannel that covers the differences between starters.
