70_Fastback
Hell Bent for Speed
I'm sure most have read about my engine misfortunes up in Des Moines. I'm finally going to be able to tear into it Saturday morning.
But baring my assumptions about the gear drive set failing. Would you go back with another gear drive? I was running the Edelbrock Accu-Drive gear set:
http://www.jegs.com/i/Edelbrock/350/7892/10002/-1
I've tried doing some research about gear failure statistics, but come up short. I do find timing chain failures though. But that could be because the 'general public' runs the conventional chain...?
If you were in my shoes, would you be inclined to go back to the gears (if that is the problem) or change and go with the more traditional double-roller chain?
Anyone else experience a gear drive failuer vs. chain failure?
Open for discussion; thanks.
