Jonk67
Ok, I've got my red 1/0 cable and have started laying out my route from trunk to starter. I plan to place the battery where the black box is, right on top of the rear end to the right side. I have an altima redtop that I will lay down posts towards the trunk and leave extra cable so I can pull it to where the spare tire is if I need to get to it which I don't expect to often. The right side of the box will be bolted through to the frame and I'll probably add some 1/4" flat bar to tie the right side of the box to the frame too. I will be using rubber grommets where ever I go through a hole.
How does this route through the rear look? Where it is laying it clears the rear seat panel and window operation. I cut/bent/folded the thin piece of metal at the floor to keep from cutting the cable and will put some slit fuel hose over top/bottom metal edges to protect it. Does this look ok for a route? From here it runs forward down the rocker channel to the front kick panel.
In the front I am inside the kick panel and trying to find the shortest/easiest/least prone to water outlet. I tried it through the antenna hole but that's doesn't seem very direct. I'm thinking of drilling a hole where the blue tape is in the firewall if I can get the cable past the heater motor up in that corner. Of course I refurbed the heater and reinstalled before doing the cable...
I am probably going to enter the engine bay where the blue tape is forward of the shock tower as I'll also be putting a junction box there for all my forward electrics (headlight relays, etc.). I was going to go through where there's already a hole pointing right at the starter but my headers allow no room to go through. I figured it'll be easier to come from the front of the headers and between them and the block to the starter.
Tips, hints, ideas?
Jon
Tips, hints, ideas?
Jon
