"Opentracker" said:Elongating the 1/2" hole into a slot is the hardest part of this mod. Put the saddles in with the #1 plate and tack weld (That will give you equal adjustment on both sides), remove plates and weld. I use a 3/8" carbide burr on a hand drill to clean up the slot after using a drill to make some holes. It is a easier with the motor out but it can be done with it in. Take your time. You don't want to make the slot any wider/taller than 1/2".
"silverblueBP" said:What John said!
"hivewax" said:got hit by a spatter, left a hole mark in the palm of my hand!
"AtlantaSteve" said:OUCH!!!! :yikes
too bad they don't make special gloves just for welding. :doh
"silverblueBP" said:or for bystanders :yikes
