tarafied1
I borrowed a MIG that is 180 amp 220 volt. The guy I borrowed it from does not have shielded gas and is using flux core wire. I borrowed it to weld the frame up on the 65 as my 90 amp MIG wont make enough heat for the frame rails.
My question, should I try to weld with it as is or get regular wire and hook up my tank?
I've never wire welded with flux wire before. I really don't want to screw up the frame!
Thanks
Thanks
