Dne'
My heater hoses are just kind of hanging right now, what are ya'll using to hold your heater hoses in place? When they get warmed up, they start sagging down towards the headers.
dne'
dne'
"blue65coupe" said:Mine are just laying on the valve cover/intake.
before switching to the 5.0 hardlines, mine were just laying on the intake."blue65coupe" said:Mine are just laying on the valve cover/intake.
"Jonk67" said:Did you close in the factory hole that was at the top of the shock tower center? can't see it as your hoses are in front of it. Seen here at the top of the '^' section of shock tower:
Jon
"AzPete" said:That bracket on the carb is most likely to keep one hose against the choke spring so it opens the choke as the coolant warms up.
"Jonk67" said:I was thinking, use something clean like this:
http://www.summitracing.com/parts/BSP-68320/
paint it engine bay color or black or just leave it billet to match the VC. Get a longer screw, run it from the tire side through that hole into the clamp (may need a sleeve for the bolt for how much bigger that stock hole is) and snug it up against the shock tower with a nylon washer to protect paint. The screw will need to be just the right length, you can cut to fit or use washers on the tire side to get it just right.
You'd have a smooth install that would stay put and no screws showing, just the hoses pulled up against the tower with the smooth billet.
Jon
