'67
Ever since Craig and I installed a oil gauge (original type which Craig checked out and worked) where the clock use to be it never really gave a reading. It would move a little but not give a real reading.
I have since learned that the oil sensor is not getting enough voltage and that there is a relay under the dash which has one other sensor connected to it...the fuel. Of course getting a new relay would mean the gas gauge probably would not read correct and the float would have to be adjusted.
So...where is this relay under the dash? And what does it look like?
M
M
