This year's projects:
Repaired leaking thermostat housing gasket. Installed new gasket and thermostat while there. Also flushed the coolant.
LED instrument lights
Install oil gauge in clock position
Rechrome rear bumper
Took the bumper off and deleivered it to the chromer.
Found a flip gas cap at a flea market and since it looked better than mine will use it. Getting the base rechromed with the bumper.
Took panel cluster out. Craig offered up a spare oil gauge which I promptly bent the needle (Craig straightened my needle).
Installed a oil sensor with slight bending of the oil dip stick housing.
Cleaned the housing and repainted the black inner circle of the Speedo and Tach.
Bought new lenses from NPD (Scott Drake)
Bought the LEDs from Mustang Project (in blue)
This weekend the panel goes back together.
