Need to see pics of a 67 fastback trunk rod.  Specifically the pass side end of the rod and the bar/piece that goes from the rod to the solid pat of the hinge.  We are reassembling and using the parts that were on the car but it had been monkeyed with having a carriage bolt and a nut welded on.  The flat bar from the tension rod to the hinge that acts as the stop when open(that part is working fine) hits the hinge just before the trunk is all the way closed.  Wondering if the straight flat bar is not the original correct piece.
