Haven't decided just yet on what to use for mounts when I drop in the engine. I have the original early 65 stands I could use with a new set of stock upper mounts. I'm using a new Air Gap intake and am a little concerned about hood clearance. My air cleaner* does not have a drop base and one is not available. I also want to use a carb spacer as well. So, I'm thinking TCP style adjustable mounts to get that 1/2" drop and maybe a little front to back ability as well.
Two questions.
1. Do I need the drop for hood clearance?
2. For those that have the adjustable mounts, how much more motor vibration do you really feel?
*from the mounting surface on the carb to the top of the air cleaner nut is about 3 1/2"
Two questions.
