Gary's '66 conv.
Putting a 302 in place of the 6cyl. Can I use the 6 automatic trans?
Not 100% sure if you can or cannot use it. I would probably not try and use it, reason being most automatic transmissions utilize more clutch packs in a V8 trans than they do in a 6cylinder trans. Although if you are rebuilding it some autos can be brought up to V8 specs by adding the additional clutch packs.
From Infinity and Beyond
Never argue with a Moron, they will just drag you down to their level and beat you with experience.
I'll take all the help I can get. This is my 1st Ford project. I do know the '66's had a 6 bolt bell housing as opposed to the 5 bolt so I'm not sure if I need to change it. Putting a TCI front suspension under it and hoping to just swap the engine. Really want to try and keep the C4 trans. Not opposed to having it beefed up if that is apossibility.I have done the swap, let me know if you need any advice on parts. Are you just swapping engine or doing a conversion?
...because all the cool kids have TCI front suspensions. That and getting rid of those damn shock towers really opens up the engine bay!Why the expense of the TCI set-up? If you are just dropping in a 302 or such it's not needed. You can upgrade the stock pieces with some improved designs like roller perches, etc. and save quite a bit of money. Plus it will handle and drive at least as well if not better.
did. Do you mean he is not a reliable source?Too late on the TCI. Its on the garage floor and I'll be happy to get rid of the shock towers. Still looking for advice and help on the C4Why the expense of the TCI set-up? If you are just dropping in a 302 or such it's not needed. You can upgrade the stock pieces with some improved designs like roller perches, etc. and save quite a bit of money. Plus it will handle and drive at least as well if not better.
