hopefully you won't have to tow me!
now that would be great! but you will have much more fun in OklahomaToo bad I'll be in Oklahoma at the Mid Am Shelby meet or I could follow you all with the trailer.
What do you think this is? Chicago?The vote tally is really disappointing.
shouldn't you be in the garage? I voted for you, now get busy!It's the dead that vote in Chicago. Get it right.
It feels like I live out there. I like It!shouldn't you be in the garage? I voted for you, now get busy!
The good news is the mustang project wallet has run dry which means I can't buy anything else to add to the work load. These just arrived today and should be the last notable spend on this project. I hope the next necessary purchase will be its first tank of gas!I votes Yes, I believe he and his wallet can get it done.
You probably know I installed those on my coupe as well. They are made to the highest level of workmanship and material. I suggest you load the trunk with weight equal to the weight of a full tank of fuel to set the pre-load. If youre REALLY OCD you can load the driver seat with weight equal to your weight. (Both of which I did).The good news is the mustang project wallet has run dry which means I can't buy anything else to add to the work load. These just arrived today and should be the last notable spend on this project. I hope the next necessary purchase will be its first tank of gas!
That is not OCD, that is doing it correctly.You probably know I installed those on my coupe as well. They are made to the highest level of workmanship and material. I suggest you load the trunk with weight equal to the weight of a full tank of fuel to set the pre-load. If youre REALLY OCD you can load the driver seat with weight equal to your weight. (Both of which I did).
Yep. All part of the plan but thanks for pointing it out. So much going on my pea brain tends to forget stuff once and a while!You probably know I installed those on my coupe as well. They are made to the highest level of workmanship and material. I suggest you load the trunk with weight equal to the weight of a full tank of fuel to set the pre-load. If youre REALLY OCD you can load the driver seat with weight equal to your weight. (Both of which I did).
