3175375
just no smoke
impressive, I get about 10mpg with my 72 Chevy pickup empty. AND I have all of about 80 horse power! But it's a hybrid. It burns gas and oil. I used two gallons of oil on the power tour.I get 12 pulling 14,000 [emoji12]
My 2000 7.3 will haul ass and pull a house off the foundation. I've had almost no problems with it since purchase in 04. Just regular maintenance. Closing in on 160k.
Variable turbo is what I had to re-do. I also did turbo oil hose replacement n a couple of other things. I also put a new harness in the trans valve body after a 1.50 plastic sensor failed that caused the engine into limp mode. My truck is an 03 that was built in Nov 02.All mine were stock, because I had no reason to tune them, and the 4R100 didn't handle it so well. In fact, it was a bit of issue. You may want to look out for those tuned 6.0s though, even though I'd never tune one for the obvious time bomb reason, there's not a 7.3 that would run with one. A tuned 6.0 is almost as fast as a tuned 6.4.
I think you guys are a little confused. There are 3 different 7.3's.
The n/a version put out 185 hp and 338 ft/lbs torque.
The turbo 7.3 put out 190 hp and 388 ft/lbs of torque.
The Powerstroke 7.3 started at 210 hp/425 torque in 1994 and ended at 275 hp/525 torque. The Powerstroke has a lot of performance parts available but the earlier versions have very, very little available.
btw, the Powerstroke 7.3 and the earlier 7.3's share only 7.3 as the displacement. Nothing or very little else is shared.
Confused because you think all 7.3's are the same. By simply calling them 7.3's when the powerstrokes are distinctly different.
You cannot tune an older 7.3. The aftermarket simply has very little for them.
When talking about variable turbo's and tuning a 7.3 and not keeping a 7.3 stock all clearly indicate a Powerstroke.
For those that don't know this stuff it is misleading.
I like my 94 turbo-diesel as slow as it is and as unmodifiable as it is. It is CHEAP to repair. I LOVE the way it sounds. It is awesomeMy 93 F250 diesel does not sound the same.
