blu67
You need a drawing done so we can see what it's really going to look like........
I know a guy.
I know a guy.
No doubt. Just have to get things straight enough in my head on where I'm going with it so I can let you know what to draw. You did the one of my car LONG before it got going and If you didn't know what to really look at it ended up almost dead on the rendering. You'll get the call just as soon as I figure it all out.You need a drawing done so we can see what it's really going to look like........
I know a guy.
Bet he doesn't get that offer much.I’m here when you’re ready.
I spoke with Dan @silverfoxtrans.com and he gave me some guidance. Can't say enough good about him. Didn't try to sell me just told me what way to go. For my need suggested a '98 or newer stock AOD out of a truck coupled with a V6 converter (looser than V8). Said I wouldn't break it (good for much more than I will be pushing). Got a line on one now I will be checking out.Look at http://www.clickclickracing.com/forums/forum.php it's got a lot of information about AOD's. Silverfox has kits for rebuilding and strengthened AOD"s. He has a CV valve bodies that eliminate the TV cable. http://www.silverfoxtrans.com/silverfoxtrans.com/VB_AOD.html
Chris,
I will contact you in a couple of weeks, once I get my stable populated to get a picture made.
Steve
Good work!Spring is trying to arrive here and I am back in the garage. In between finishing up a few items on the car I also started the process of converting the truck over to 12v so I could fire it up. Didn't see the sense in getting a 6v battery only to have to buy a 12v soon so dove into the electrical changes. Not much is really needed to be honest. Have to change out the starter solenoid, horn relay, coil and some stuff under the dash (wiper motor, radio). The big thing I wanted to do my way was convert the stock gauge cluster to operate on 12v with the stock instruments. I could have used the same voltage reg as on the mustang cluster but wanted something a bit more refined. I bought some electronic regulators and heat sinks and made the switch. For about the same price as the mustang's crude device mission accomplished. Also swapped out the points set-up for a new Pertronix system.
View attachment 30926 View attachment 30937View attachment 30930 View attachment 30932 View attachment 30933
Chris, I will be contacting you soon to get a drawing of ‘Doug’, ‘Farty’, ‘Tigger’ and ‘Shamu’ in my monster shop.You need a drawing done so we can see what it's really going to look like........
I know a guy.
Nice!.....I think those are cars......
