do you have pics of the inside and outside of the drum(s)?
No
Mark
couple more questions:
Do you have a parking brake?
If so can you cause the wheel to lock up with parking brake set, when shoes/adjuster is set to spin freely while lugs are tight?
Do you have an adjustable proportioning valve?
can you set the shoes/adjuster to spin freely and adjust the proportioning valve to give more rear pressure? And by doing so, then cause wheel to lock up when brakes are applied but still spin free when not applied?
I agree with you but he did say that he can back off the adjuster so that the wheel/drum spins freely when lugs are tightened but then he has little to no braking from the rear...As I am sure you are aware....this makes absolutely no sense. The drum should only be in contact with the axle flange, with the exception of a slight drag from the shoes. Tightening it down should just cinch the drum to the axle, unless the drum is contacting either the backing plate or the shoes. I know its a bit of work, but I might be tempted to pull the shoes off and retest it, just to eliminate that option.
okay, is the alternator grounded to the block? That was my problem...
When you put on the new shoes and drums, did you replace the hardware like the springs? Maybe compare the length of the old ones to new ones. Maybe the new shoes need them to be shorter.
Sent from my Pixel XL using Tapatalk
when I hooked up my alt I was getting sparks, turns out I was hooking the ground up to the positive post of the solenoid. I know, I know this has nothing to do with the brakes. I was trying to be funny but I guess you didn't read my thread on this when I was asking for help. It might have been funny then...Wtf?
Mark
I see you are now messing with everyone's heads on this one. At least they get pictures! After reading all this again and having pictures to help stir the brain cells I have a new thought. I'll call you tomorrow to share. Want to look at something at home to confirm first.
Yeah what he saidSure....don’t share with the class! I’ve been waiting for you to chime in and now you two are going to have a phone date!
I suspect your problem may be with the drum housing and wheel. Swap drum housings left to right and see if the problem remains on the driver's side. Tighten the lug nuts. If the problem remains, it may be the wheel. If the problem still remains, then something is wrong with the brake assembly/axle/flange housing. If it migrates to the other side, there's a problem with the drum housing or with the wheel. Try to isolate which of the three main pieces is causing the problem.
Yeah what he said!!I suspect your problem may be with the drum housing and wheel. Swap drum housings left to right and see if the problem remains on the driver's side. Tighten the lug nuts. If the problem remains, it may be the wheel. If the problem still remains, then something is wrong with the brake assembly/axle/flange housing. If it migrates to the other side, there's a problem with the drum housing or with the wheel. Try to isolate which of the three main pieces is causing the problem.
Yeah what he said!!
Yep!!!!Adding so much to the diagnosis I see [emoji23]
