limeyboy
Midlife,
I've just read an old post of yours explaining that to get the fuel gauge to read correctly you need to "alter" the CVR.
I've just fitted an electrical oil pressure gauge ( taken from a Tee piece back of the block) and a water temp one ( sender fitted into the water pump 351 Cleveland).
The readings seem good 77 / 80c and 5 bar cold fast tickover to 1.2 bar 600rpm hot tickover and 5.4 bar cold 3,500 and 4.4 bar hot 3,500 with 2.4 bar 1,000 rpm hot.
The original oil pressure gauge has always read flat out only dropping to halfway at lowest when hot ( 600 rpm) going back to High when reved up much and the temp gauge has never moved very far from Cold.
Now my fuel tank ( California tank so 16.5 UK gallons ) goes a long long way passed Full when filled and I think it has about 4 or more UK gallons left in it at Empty so if I should alter the voltage regulator would that -
1- drop the Fuel tank reading
2- drop the oil pressure reading
3 - RAISE the temp gauge reading ( as I believe it reads low)
A lot of explaining for a simple question so thanks for reading it and replying hopefully.
Jeff
PS would a transistorised CVR cure this?
Jeff
