Spanner wrench is the name for it I know. First time I ran into such a caliper was on an old Saab. Just welded a couple bolts about the right diameter to a piece of flat stock and instant tool!
yup thats essential what i orderedOoh. Its like VW did use prior the common electric e-brake system used nowedays.
Something like this ??
lol, yall have more fun unfortunately i dont have a way to get the truck back out and almost got stuck in the driveway so i decided against more funYou need to bring your butt up north and we'll show you how to "play" in the snow. You gotta ramp up your speed a bunch of notches and then send her sideways to get things going. Winter is all about driving down the snowy/icy street and swinging that rear end back and forth like a pendulum. Its drifting without the tire wear!!
i had the roll on epoxy and it went on the roof well so wanted to use the kit i bought. I sprayed it in the past, certainly the way i ill be doing it from now onEpoxy is not high build when it comes to sanding. You've got your work cut out for you. A good epoxy is like rock when hardened. I think you'll need something a lot more aggressive than a simple 400. To knock that down I'm guessing 220 or even more. Why did you choose to roll it? You've sprayed lots of stuff before.
Have you got another '65 stashed away in the other bay, I see?
Fair enough, i did roll lightly but i think i may of missed a step, i looked at some videos and apparenly your supposed to basically blot the roller on paper before applying. I also wonder if i should of just stopped at one coat for the dayWatching that last video I will say you didn't get runs your got SAGS. You put the stuff on way too heavy and the weight of the material simply couldn't support itself via adhesion and well, you get what you got. This is why we spray it on. You can achieve coverage much easier with less material. No amount of thinner and/or hardener, regardless of what you used, would have prevented that mess.
I sure hope it is a second rate epoxy simply because if it cures and hardens like a good one...you will be hating yourself in the morning! Either way, accept your fate and have at it. You have a ton of material to remove so don't try and be cute using too fine a paper. It will just clog up quick and at best give you a wavy surface. Go coarser so the dust can fall out and the paper dig into that stuff. You are bound to cause some bare metal before its all over. Chalk it up to lesson learned. Better to get that off and do it over with a good product that you SPRAY on. You don't want that mess under your final top coat. A paint job is only as good as what is under it, as they say.
