1967 Build called Electra
Set her up with a 1996 Miata Console. Fits pretty good
working on a double din console attachment
more pics of the forming
"tarafied1" said:
I got to see this thing in person today! Lookin' good man. It was nice to meet you too.
you two coulda called me. i had beer! all gone now, didnt want it to go past the expiration date (like that would actually happen!)
Thanks and It was nice to meet you as well. Now I guess I need to go check JonK's thread to see how that went.
He just stopped by to pick up some seats. Otherwise we would have :)
yes, I thought about dropping in since I was so close but my main objective was to get to Jon's house to work on his 67
awww, i was just funnin' with you guys. i know all about crazy schedules. :thum you are all welcome to drop by anytime though...
you might regret saying that... :dun
OMFG I hate whoever ****ed this car up so bad!! The sorry sumbia mutha of all that is wrong in this world. Today i decided to take the fenders off. I need to start looking at the suspension, replacing the springs at the least. Well the drivers side fender came off fairly easy and then i got my drivers door lined up better. All was going good. Then.....i find the front top fender bolt has just a nut on it. Then i find the front section that holds the valance from fender to fender has a self tapping bolt in it and the top was shaved almost smooth and then and FU**in then i find what i thought was just some bondo in the gap on the bottom near the rocker panel is a freaking WELD! Not only did it make me mad but i ended up messing up the door paint while cutting it out... I hate the PO or PO to the PO or who ever da **** did this
UGH!!!
So on another note the side is dented in a bit on the drivers side right below to cowl but not too bad. Surprisingly everything is solid looking other then the passenger side about 8" of frame rail right below the battery and well battery tray area. Its prepped and now i need to get some cutting blades so i can shop the side of the cowl off and try a patch
I did drive it this morning before dis-assembly
When I got Mid in 1998, I found both front fenders welded to the rocker panels where they butt up against the fenders. Dumbasses...
I feel for ya.
at least is has a caring owner now! It looks pretty good with those wheels. My son wants to do a semi-gloss black on his 69 and use the wheels off my 99 GT.
Is the UCA suppose to be on an ANGLE? Mine has a bolt hole above the rear of it and seems to be bolted in on about a 30 degree angle towards the firewall
Hard to follow what you mean. Pic?
