limeyboy
Hi all,
First some background -
It is illegal to have any red flashing lights on a UK vehicle ( The same for Bruno as well I think?)
So a guy here in the UK makes boards where the centre orange LED's are so bright they shine orange through the red lens - result!
There are pushbuttons on each board so you can choose 4 different ways of flashing as well.
My problem is that having a '70 ('71 was also the same) I'm trying to deal with the "marker lights earthing through the indicator filaments.
I've run a mishmash of LED and filament bulbs with an LED relay for a couple of years and it's worked fine but I now have this problem -
With the LED rears on sequential the relay in the board "clicks in and out" and the flashing is erratic BUT when I turn the side lights on everything is fine ( the relay on the board clicks in and stays in) and they work perfectly ( not a stable supply without the side light power???)
I've spoken to the guy who makes the boards ( nice guy but I think the marker light bit which he didn't know about has thrown him) and he said that the "clicks in and out" on the board is due to not enough power keeping the relay in.
I have tried adjustable relays which make the sequential's work fine but then "lock" all the other bulbs, I've also tried various combinations of LED and filament bulbs, LED and non LED relays but when I got the indicators to work OK in one combination as soon as I turned the side lights on they all locked up
I also tried wiring a normal 21w filament bulb in parallel but that made no difference.
So my question is if I cut the black earth wire on all 4 marker lights and earth then properly will that stop the "back feed" and give me a fighting chance of getting them to work properly?
I like the marker light flashing bit and I've seen the "cougar unlimited fix" but it's very expensive for me to import and I can't be sure it would work with my board.
Perhaps Midlife can suggest a miracle cure![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any thoughts, ideas gratefully received
Jeff
Jeff
