Hello Horseplay, thank You!I use a Lokar pedal set-up in my mustang with a FiTech. Shouldn't be all that difficult to find what is causing the extra effort. As Brett suggests, disconnect things until you find where the main issue lies and do what's necessary to smooth things out. With a lot of throttle connections using a cable, having a bad angle can really accentuate the problem. You can use leverage to overcome quite a bit.
