That boot doesn't really seal against anything as much as "cover" the fuel inlet. Pump hoses like that have a vacuum that collect the fumes created when filling up from escaping into the air. You can still get splash back and fuel spills."jims6t6" said:"68angrypony" said:Im in so cal. I know in some of the other stats you guys have the pumps with the metal filler and no rubber surround. In so cal we have a rubber boot that seals around gas fill hole. Do you know with that set up at the gas station if there are still issues?
Unless they have changed the nozzles since I left CA (1994) it still splashes out but not as bad.
