tarafied1
Re: 302 is combing out.
when mine broke, I could see the crack in the casting.
"tarafied1" said:I broke a pump that way but for a different reason. 460's and older 429's have a different size pilot. But I broke the pump trying to "pull' the engine and trans together with the bolts.
I think Terry hit on the head, I hope there is no damage. You might be able to separate the engine and trans in the car without pulling either. Just keep the trans on a jack and pull it back enough to get at the converter.
"jmbour66" said:As you all are figuring out, I know just enough to be dangerous!
"Grabber70Mach" said:Also make sure that the converter drain plug lines up with the hole in the flex plate. When everything is aligned correctly the trans and engine should just slide together. You should never use the bolts to pull them together.
Sent from my DROID BIONIC using Tapatalk
"silverblueBP" said:I use / would use the pointer.
