apollard
If he's got stock Ford components, the firing order would be different. However, Comp and many others make std firing order roller cams. Also, the base circle of the cam can affect pushrod legnth, so not sure that will help much.
You might could pull a pushrod and shine a light down the pushrod hole. Not sure how much you might see, but if you see the dogbones or a link bar you know you have a roller cam.
