AzPete
My Dad was a pro at welding pot metal. I never developed the touch for it.... He always had a special rod and used an old arc welder. I saw tools he repaired last better than 10 years so I know it can be done.
"66gt350" said:I've heard that it don't weld worth a darn, but what about brazing using like a brass rod or even doing some silver soldering to fix 'em? both my headlight buckets have had that piece totally broken off, so I'm stuck with either the jb weld solution or new re-poop pieces.
"napaguy" said:Ryan and others,
The mans name is Harland Lippold and his business is horse heaven. His email adress is HorseHeavn@aol.com
He can be slow but will get back to you via email. He should be able to give you a more thorough description of what they do.
I also got to thinking that sluggo should have something to add to this being that hes a body guy and has probably faaced this before. HTH
"Indycanard" said:I bought repops for my 65 Conv (from NPD). Absolute crap fit for both. By the time I slotted the attach holes (wallered-out for you mid-Westerners) to get the buckets aligned with my fenders, very little metal remained around a couple of the holes. In the end they did fit, but I had to use washers and other tricks to make it look descent.
