So I have my car done and I am desperate to drive the damed thing but every-time I go around the block the secondaries hang up and I cant get it to stop doing that.
I changed out that white plastic choke stop with a screw because it was bent after decades of use just in case that could be an issue
This is the mod I am talking about,
But whats interesting is that new screw does not touch the linkage for the rears like it is in the pic that gave me the idea, should it be in contact all of the time?
From what I have learned that plastic stop (now a screw) was just to prevent the secondaries from opening while the choke is engaged and not for pushing the rears closed. So that "Mod" may have been a waste of time based on erroneous information.
Initially I thought it could be the diaphragm lever or the rear throttle shaft needing some attention, but I took the rod off of the diaphragm and both the rear shaft and the lever work smoothly, the rear throttle shaft opens and closes without any drag at all.
I started to think it must be a vacuum issue but when I google about the 4100 and secondaries most of the hits are about them "not working",so mine may be working to well or to early etc..?
Then I started to hear all of the conflicting stories about that check ball in the secondary diaphragm "5th hole" and now I am getting confused.
I did not use a ball in mine, but after considering my issue of hanging once the rear bore is activated and factoring in how soon they come in, maybe I need one?
The carb is a 65 but I cant remember the exact foot stamp number, but it is definitely a 65 because the fuel line threads directly into the body with no filter, I remember it being for a 289 car when I looked it up initially.
Here is my diaphragm body, do you know if this type should have a check ball? If so what size?
Here are some other pics of the carb.
