Another question for the electrical gurus (Mid). I have this 66 Mustang 289. All stock (for now). It sat 30+ years. I just got it running with a carb rebuild, new cap/rotor, points, plugs and wires. The coil was also replaced. I did not change the condenser until second set of points. It will run good for a while then die. I eventually discovered that the plastic rubbing block on the points looked melted and point gap was going away. I replaced points again, this time new condeser as well. Same thing. So I figure I have a problem with points getting hot. Sure enough if I run it a short while, pop the cap, the points are smokin hot. I have it wired the way it appeared to be when it was parked. But I did also have to replace the starter relay (solenoid) and the starter. There is no wire from the solenoid "I" side. Only "S". Anyway, I checked the voltage at the coil + side key on, it's batter voltage. I also disconnected the points and checked coil - with key on and get the same (battery voltage). So my thought is someone bypassed the resister wire at some point in it's life because, shouldn't there be a wire from the "I" side of the relay that's at 12V during start and the coil positive at ~6V when key is in run? My 67 is so modified it is no help looking at it.
