Jonk67
I guess this applies to engine drivetrain as it's fuel for the engine, I couldn't find a better section to post.
Well i replaced my '67 5/16" metal fuel line from the tank to FP with a new '68 3/8" line. The '67 routing is along the trans tunnel, thru a hole in the forward tunnel crossbar/reinforcement, under the frame and up the outer frame to the front apron.
The '68 runs along the rocker just inside the crimp lip to the drivers torque box. I have a hole on the rear of the torque box but none on the front of the torque box. It looks like there should be a hole in the front torque box to line up with the rear hole as this is how the 2pc. fuel line lines up.
Is this correct?
Can anyone supply a pic of the drivers torque box front (directly behind the tire)? or measurements from the frame to center of hole and bottom of torque box up to the center of the hole? I want to make sure this is right before I drill a hole.
On top of this I can't find my camera to take a good pic for an example.
Thanks, Jon
Is this correct?
Thanks, Jon
