"AzPete" said:Doubtful....it would be a real pain I would think if it was possible. Why not remove them from the engine and leave them in the engine bay. Then set in the new engine and attach them then?
"RapidRabbit" said:That is up to you on how you want to move forward.
They were computer controlled , but I would look for later year efi that is mass air. I believe the tbirds were speed density for 86. I ended up converting my 88 setup to mass air. It's just more compatible with upgrades like heads and intake and such. Not that speed density is bad. If you just want to run a standard setup it works just fine. You will need a few other pieces to go efi also, depending on what comes with it. try to get any wiring and brackets that you can. Tracking done some of the little pieces has put me behind on my swap by several months. If you go with it as is I have a speed density computer I'm not using.
Pat
