Another new brake system
Shaun
Here is our latest brake system. Part # ST13X11-4P-ALUM. It features a 13" x 1.1" 1pc directional curved vane rotor, 4 piston forged aluminum caliper in either bright red or gloss black powder coat. Direct bolt on to 65-73 DRUM spindles and will fit under some 16" and most larger wheels. Please visit our website for more information and to download a wheel fitment template.
A
Anonymous
Guest
Your title should read "Likes pouring salt in wounds"
:yah
Grabber70Mach
Looks nice Shaun. Have you ever thought about coming out with a bracket to adapt the hydro-boost setup into our cars?
Shaun
All the systems we produce work so well manual I've never looked into it to be honest.
Shaun
Mark,
You may want to sheild your eyes...
Another bad ass new brake system, part # ST13X125-2PC-4P-ALUM. This bad boy features a huge 13" x 1.25" custom designed rotor mounted to a lightweight, high offset aluminum hat. This enables this system to fit under a 17" Torq Thrust II style wheel without wheel spacers.
The forged aluminum 4 piston caliper is so radially compact this system also fits some 16" wheels.
By maximizing the size of the aluminum hat and minimizing the iron rotor ring to only the pad swept area, we've reduced the weight of the entire rotor/hat assembly to only 15lbs per side. That is 3lbs lighter than our 13x1.1" one piece rotor! Check our website for more information, pricing and to download a wheel fitment template.
