SELLERSRODSHOP
imho, it would be wise to use the old block & iron heads instead of the aluminum. i've got a porta power here too..... :vic
"buening" said:I'd recommend using heat at the location where you want the headers to bend when using the portapower. If you don't use heat at the desired bending spot to "persuade" the header to bend at that point, there will be a lot of stress on the header-to-head flange welds towards the back of the head . I'm not talking about getting it red hot, just localized heat from a handheld propane tank or something to cause a weak spot. The header will bend at its weakest point with the portapower, assuming the welds at the head flange aren't the weak spot. My two cents
