The car pukes and pukes out of the radiator overflow, but it is not overheating--driving it runs right in the center of the stock gauge (and I've checked it with an laser thermometer as well).  I read this from another thread:
"Now on a side note, If your getting a repeated coolant purging or small air bubbles in the coolant stream after warm up.
You have a seeping head gasket condition. Compression gases are being forced into the cooling passages and will purge the coolant.
You can eather get the test kit that uses a dye to reveal exh gases in coolant or try the ballon trick by closing off the overflow tube and stretch a balloon over the filler neck while it idles. If the balloon inflates, there is gases being pushed in.
Another way is after you have the rad completely topped off, run the engine at 2500 rpm for 2 min and shut it down.
If the coolant starts purging from the overflow you have gases present."
Perhaps it's a very small leak, so it's not overheating (yet)? After each drive, I need to add about 1/4 of a gallon of radiator fluid... I realize that I am overfilling each time and it will puke some coolant to equilibrate, but I've never had a car that likes the coolant level to reside below the first row of metal in the upper part of the radiator (I always see a little coolant over the metal, when looking into the top of the radiator). This is a very old block, so I assume there's some rust being liberated with the antifreeze, but there is definitely a rust/red color to the used antifreeze that's puking (along with the green), which was a symptom of my last bad head gasket...
