A
Anonymous
Will a 6 bolt std 289 bellhousing work on a 351C?
The 289 (starting in 1965), 302, 351-W and 351-C all use the "small block" 6-bolt bell housing pattern. The 400, 351M/400, 390, 427, 428 and 429 all use the "big block" bell housing, which are heavier, more difficult to find and more expensive than the "small block" size.
"hivewax" said:and, what are you replacing the T10 with?
