Jonk67
Ok, before I start running the brake lines (installing PDB) I will be using the new SSBC all-in-one adjustable prop. valve:
Will the brake warning switch on it work with my factory wiring one?
Will the electrical signal from the sending unit on this SSBC unit correctly activate my dash light if I loose pressure? I'm guessing that I connect one of the 'tits' to my wire and ground the other? I'll have to look at my stock switch to see if it has 1 contact or 2 ('67 original drum/drum nonpwr). I know the stock warning switch won't work on the SSBC piece since it has a pin sticking down that has to be pushed in by a sliding vavle in the stock prop valve.
Thanks, Jon
Thanks, Jon
