daveSanborn
You could drill a hole on the inside but I doubt you will have enough room to try and weld a nut in there
Why would nuts need to be welded inside the framerail? With holes drilled on the inside of the framerail to allow access, simply install a nut and washer onto the bolt and tighten. The internal nut doesn't "have to be" welded in place. It's technically not welded in place on factory installs... it's retained within the aforementioned "cage".
