Camaro, what to do with it?
if you can age it back to a 1970 model it would be nice. I am unsure if that body can be retro'd back tho. The windows look the same but I suspect the front end has lots of differences...
If you did that, make it a trans am track car.
Here you go.
http://www.vfnfiberglass.com/7081camaro.htm
F-Bomb dragstripper here Craig comes lol.
Bill
"Horseplay" said:
used to drive me crazy spelled that way
Me too, but you had to consider the source...the very old and decrepit source.
I drove to Atlanta today, about 5 hours drive. Had a lot of ideas on the way. I like the split bumper front-end. If I retro the car I wouldn't worry about the back glass. I could part it out, I could sell it whole, I could see if I can trade it for something else, or... I could use it for my drag car and turn the drag car into a real car....???
I have talked to Mark about his T10. Camaro's used super T10's until 81 so I could put my 5.0 and a T10 in it. That would be cool to piss off the Chebbie guys!
An LS swap would be cool, those make big power. I could get a cheap 350/350, Sheldon says they are dirt cheap.
I don't want to blow it up or make a planter because I don't want it in my yard or all over Duane's yard.
I'm thinking a cheap drag car, no paint or body work, no worries if it looks good. Just drop in an engine and trans and go to the track.
I'm surprised it wasn't in hieroglyphs.
The two of you are down in my little black book of cursed folks.... :rant
Phhht, been there done that and have the document that lifted it!!
Are you sure the super T10 shares the same Ford T10 patterns? I've got a 76 T/A Super T10 here that I can take measurements off of if you need somthing to compare too. I know the Muncie M21/22 with the fine spline input matches up to an ST10. I'm not sure that the ford and GM versions are interchangeable.
Do you know what rear end is in it? A 12 bolt would be more desirable than a 10 bolt...
