So I am close to having swapped out old suspension and steering parts for new OEM parts. I also did the Shelby drop. I’m going to try and get my alignment as close as I can before taking to someone else, if needed.
Here’s my problem and it is due to ignorance. When I pulled out my upper control arms, all the shims went everywhere so I don’t even have a clue as to what was done on the old set up. I do know from threads exposed there was a pretty good difference between each bolt. One had a lot of threads and the other was close to being even with the end of the bolt.
Is there a way to get a rough estimate on alignment before I get everything back on for the real alignment? Like is there a rule of thumb or rough measurements of the control arm vs something else so I can get close on shims needed front bolt vs back bolt as a starting point? I would think the Shelby drop would impact the number of shims needed overall.
I don’t know the history of the car and would not be surprised over its life there have been impacts of what ever kind that result in the space not being true.
So any help is welcome. Let me know if I am totally off in my thinking. I don’t want to be chasing a problem created by my stupidity.
Sent from my iPhone using Tapatalk Pro
