You may need to go back and check timing and all.....a basic tune up check....to see if anything was out of adjustment to make the previous pos work.
That is kinda what's confusing me. When I bolted on this one it fired right up and ran but now it won't. I did run the pcv hose to a inlet on the intake that was capped off. (the other used to go into the base of the old carb but this one has no input). I'm wondering if that screwed things up. That is the only thing different that I can think of."AzPete" said:You may need to go back and check timing and all.....a basic tune up check....to see if anything was out of adjustment to make the previous pos work.
I did before doing what I did. 4V seems to be the common one. But I might want to keep looking. Maybe cap off the inlet and see if it makes a difference I'm thinking."AzPete" said:That could......it is said that the cylinders that it flows to may be running leaner than the rest since it is an air source after the carb. Might have to seek a spacer with a PCV port.
"70 StangMan" said:I did before doing what I did. 4V seems to be the common one. But I might want to keep looking. Maybe cap off the inlet and see if it makes a difference I'm thinking.
"AzPete" said:Is that a 2V spacer?
I've never seen one with a EGR valve...do you have a picture ??"jmbour66" said:I have an OEM 1" Spacer with a PCV port, it also has an EGR Valve. It's in great condition, I would sell it for $20.00 plus shipping.
Yea......kinda wondering myself. :shrug"AzPete" said:You should be able to plug it pretty easy.....or maybe not after checking on line pics.......hmmmm.
"70 StangMan" said:I've never seen one with a EGR valve...do you have a picture ??
