Good news... I finally took my car for a spin around the block. It sure feels good to be back in the driver's seat!!!
Bad news... the engine runs like crap.
Looking for some of your collective wisdom to sort out the issues.
Back story... new 351w engine (only ~2000 miles). It ran great last year (before I pulled the engine out and stored in my garage while it was undergoing paint & body work). Engine sat for about a year without being ran. I thought I had drained all the gas before storage, but I may have not done the job correctly.
Today... the engine starts without any problems at all. It idles great and revs ok, but under any load (i.e. my test drive today) it runs like crap... sputtering & hesitation, but no back fires.
After getting it back home... I checked the timing and it is dead on what it was when it ran and drove well before storing it. Also, the fuel pressure gauge reads the same it did before going into storage (5 psi). Next, I pulled a plug, and it was completely covered in dry black carbon soot; so I pulled all the plugs, and they all looked exactly the same. I had a set of new plugs laying around, so I installed the new plugs; started it again; let it run for about 1 minute; pulled a plug.... the new plug was completely covered in dry black soot.
Here's a pic of what my plugs looked like (not actually my plug, but they all looked like this)
Where should I start trouble shooting?
- Carburetor issues/mix is too rich?... malfunctioning choke maybe, vacuum leak
- ignition spark too weak?... How do I check the strength of the spark?... Just put a voltage meter on the +/- side of the coil while it's running? Also, how would I go about checking the voltage output?
- Dizzy?... Maybe the cap is cracked?
- Any other ideas?
thanks, y'all.
- Any other ideas?
thanks, y'all.
