castor advise
65-408
Hey John,
trying to get my 65 alignment in the ballpark so I can pic out some tires (want to go widest possible on the front)...
I am following your street specs and got the drivers side pretty close using my longacre gauge. Having trouble getting the passengers to have enough castor, I am at +.5 degrees and the wheel is already about .25" farther forward than I would like... as you know 1/4 to 1/2" is all the difference in the world on 65's for tire clearance.
I have the arning drop, my homemade version of your roller uppers, adjustable strut rods, am planning on 235 45 17 tires and have already uneven shimmed the UCA's by about 3/16" (which I am not a huge fan of)... any ideas?
Any input would be appreciated...
Thanks,
Jeff
A
Anonymous
Guest
Did you try rotating the UCA shaft forward which moves the arm back?
65-408
Can't, I have homegrown opentracker style roller UCA's, I can probably re-machine one shaft shoulder to shift the arm and put in a spacer to take up the gap...
But maybe it would be easier to just machine a tapered shim that supports the entire pivot shaft to increase the uneven shimming (without the risk of bending the shaft)...
