68stang289
Hopefully someone can help diagnose the latest issue. :g_beer
I purchased the correct upper and lower springs for a 70 428 setup from Mansfield (Bill is absolutely awesome and a wealth of knowledge in case anyone ever needs big block parts) and have installed those. The upper spring is attached at one end to the little prong on the firewall below the master and at the other end to the notch in the z-bar. The lower spring is attached at one end to the clutch fork and at the other end to the z-bar. I pulled the resto book that I have that shows the breakdown for a 70 car and I didn't see any additional clutch linkage springs needed (I know previous 4 speeds I've owned have used a return spring from the clutch fork to somewhere on the frame, but I didn't see one here). However, when I push the clutch in, the clutch pedal stays on the floor. You can feel the spring on the clutch pedal working once it get's past "center mass" either going down or coming back up.
I know the PO switched the car from a C6 to a 4 speed Toploader, but I have no idea what or where the clutch pedal and bracketry came from. I do know there is a difference between the 69 and 70 clutch/brake pedal assemblies, but could that potentially be causing my problem if he put a 69 or earlier assembly in the car? The setup the PO had when I purchased the car was a homemade frame mount pivot, modified 65/66 upper clutch rod, 351 z-bar, 65/66 style lower clutch rod and a random assortment of springs. I have since gone through and put together all the correct pieces for the setup.
