apollard
Not for a mustang, but a diff is a diff -
'04 Dodge truck (yes, I know, that's my problem)
The diff whines something fierce when moving, and has been getting worse for a while now (sort of crept up on me). Starts around 10 mph as sort of a growling, then becomes a whine, and raises in pitch as speed increases. Between 30-65 or so, it is loud - hard to understand voices on the radio loud. About 70 it seems to become quieter, likely because it's getting above the hearing range.
Does not change when accel / decell / coast, just with speed. Does not change with turns, no matter how sharp. Does not change with load (pulling 7k lbs even).
Jacked it up, and the sound is still there (ie, not tires), and is coming from the diff, not the wheel bearings. Ring gear backlash is `10 thou (range is 5-8 thou).
Read all the FAQs I could find, and none talk about a noise that changes only with speed. All say ring gear backlsh should change with load / accel/ decel. They also say a couple of thou won't cause loud whining.
So, I'm thinking carrier bushings, as pinion bushings and gear noise apparently should change with loading. But, none of the sources I found said anything about this - what say the gurus here?
