B67FSTB
The NorCal dude from Belgium
FWIW.
For those who is seeking for some info on installing all the component of a door in the right order.
The install sequence is :
outside door handle
outside door cylinder lock
latch assembly
inner door actuator
window regulator
rear window run
window
vent window
window felt kit
last goes
window bottom stopper
Here is a video from the guys you probably all know.
outside door handle
latch assembly
inner door actuator
window regulator
rear window run
window
vent window
window felt kit
last goes
