My dear, you don't have to say another word! I'll be right over!"Dne'" said:It's an aftermarket unit for sure, Midlife might jump me if I say where I actually bought it from :shy.
"Midlife" said:My dear, you don't have to say another word! I'll be right over!bj
"daveSanborn" said:Dne',
You may certainly state which AC system you installed. It's only in the "vendor evaluation" board where we try not to compare different companies/vendors. Within ALL other boards you can state "I bought a Holley carb" Or "I installed a Classic Air AC system" without any worries.
Dave
"Dne'" said:I was running the cars AC in my garage, I did have a power cat(squirrel cage fan) fan in front, and both electric fans came on(one fan would cycle). The air in the cabin wasn't being recirculated and it was really warm, or hot I should say. The gauges were 25-30/225-250 and the lines were pretty cold. The heater control valve I did help it to close a little better by hand, needs a little more adjustment to close with the control lever. The sightglass was clear of bubbles. I had it idling about 1500 rpm. I'm hoping that maybe once outside with air rushing into the condensor may help. the outside temp was about 97 and in the garage maybe hotter with the car running. I did evacuate the system for 45 minutes prior and held vacuum overnight, so that was good. So, what do you think Pete?
You're not the only Edlebrock owner. Both my cars have them. I took the holly off my 65 for an Edelbrock. It was just plug and play. It runs a bit rich, but it runs like a scalded dog now. Before, it was doggy! I need to freshen up the one on the 67. It has been sitting for a while."Starfury" said:Am I the only Edelbrock owner here? lol
First thing, move the accelerator pump linkage to the inner-most hole on the pump arm. If that doesn't work, you may need to replace the accelerator pump with a different, high volume pump.
If it only does it while idling and not while driving, you may richen up the idle mix a bit (turn the idle mix screws in).
