"68EFIvert" said:I am using a stock fuel tank with an inline canister filter then an Aeromotive A1000 pump. I have over 550 rwhp and haven't had any issues with starvation. I use the drain plug for the return line.
	Where would i go about finding this low flow pump and filter?"66gt350" said:If you can follow this spaghetti, this is my fuel system. I have a low pressure fuel pump that feeds the canister filter (which holds about a quart of fuel). Then I'm running a Mallory fuel pump that is rated at 60 gph (about 225 lph) to feed the injectors. On the return line I have a tee that dumps fuel back into the accumulator tank (if the gas tank runs dry) and, also, back into the gas tank. I've run down way under 1/4 tank, and have never had any issues. The only change I've made since the pic, is adding a fuel filter , and swapped out the Ron Morris sending unit for a McRobb unit.
