Electrical Help - 67 Coupe
Aussie67
Looking to trouble shooting thoughts.
So, I have a noise coming from behind the dash, which I have traced back to the emergency flasher can. Everything works ok, and the noise "disappears" when the emergency switch or indicator is used. I have some LED rear lights which I got from GTONavy some time ago and they work fine. However I do have some traditional light bulbs in the flasher/ park/ reverse lights. The flasher cans are the ones with the black earth wire at the top.
Do you think its an earth issue somewhere or that I'm not using the LED's everywhere?
Not sure what you mean by "noise" but if you are talking about an auditory sound you can actually hear, based on what you say about it I would take a look at the base connection points for the flasher unit and that flasher itself. I can't think of a reason to suspect the mix of LED and incandescent bulbs. Especially if all was well and working at some point. If the flashers worked then you must also have used the proper flasher piece for LEDs.
Yeah its a noise coming from what I think is inside the can. Changed the can over with a new one but still the same.
The.noise is like a soft clicking. Almost like a clock
I will recheck the connection then. Hoping that it's that simple
