One_fast67
I’m finally to the point of putting everything together and I have a few more questions. It took forever but my factory crankshaft has been refurbished. They ended up taking .010” off the mains and rod journals. Purchased the .010” undersized bearings and had everything balanced. I started checking clearances with the rod journals and I am getting .0015” of clearance. Everything I have read has stated that this tighter than what is recommended. Can I run with the rod clearance this tight? If not, what are my options to create more clearance? I haven’t checked my mains yet but what would be my options if I run into the same issue?
Second topic. Does anyone have any recommendations for blueprinting an oil pump?
