jonward786
Hey i was wondering if anyone would have any ideas about an overheating issue i had yesterday. the engine is a new rebuild with only 300 miles on it and it was the first long distance (150 miles) trip i had done. it wasnt a hot day and the air temperature was cool. noticed the temperature gauge sitting at about 80-90% the whole trip, then when i got to the garage and turned it off it overheated and coolant overflowed.
my first thought was that the thermostat wasnt opening all the way, but after doing a little more research, i read about air pockets in the cooling system and having to "burp" the system to remove the air. so the following morning i ran down to the garage, replaced the coolant that had overflowed, and started the engine with the radiator cap off. i let it idle for about 5 minutes and watched as the coolant flowed from passenger side to driver side as it should. however, the coolant began flowing IMMEDIATELY following engine starting, and i was under the impression that the coolant should only start flowing after the engine has reached operating temperature because that is when the coolant is directed towards the radiator. i did also notice a good amount of bubbles on the surface of the coolant as it flowed by. after about 5 minutes i shut it off, and replaced the cap.
i feel like seeing bubbles meant i could perhaps have removed some air in the system. but is it normal for the coolant to start flowing as soon as the engine starts?
