A
Anonymous
Guest
If they should break, the tape will help hold the pcs together so they don't end up on the track. So, yes...you are thinking correctly. One of these days I'll get some covers for them and stop taping them up.
"silverblueBP" said:If they should break, the tape will help hold the pcs together so they don't end up on the track. So, yes...you are thinking correctly. One of these days I'll get some covers for them and stop taping them up.
"blue65coupe" said:Would you please tell me what friggin' wp you're using? I'm wanting to run a crossflow radiator and I'm trying to locate a wp for 289 with ds inlet. Thanks for reminding me you've never let me know which wp you run.
"silverblueBP" said:Still have to add the oil and prime the pump. Fill the carb bowls with go juice and hit the detonator switch :wth
"BobV" said:Maybe you should use some of that tape on your valvetrain......... :hide :hide :hide :nut :confu
"stangg" said:Some guys just use a short hose to form a loop... I think it looks goofy, but was under the impression that plugging the heater hose inlet / outlet can create cavitation in the pump... I don't know f the issue is real or percieved... just thought I'd throw it out there.
"AzPete" said:If it would cause cavitation, then all the systems out there that have a water flow cutoff valve (67 and up ?) in the heater hose from the factory are causing a problem.......which I doubt. My Dad's '72 F100/302 never had a problem and it had the water cutoff valve. Also, several of the after market A/C systems use this same type water flow cutoff valve to control heat inside the a/c unit.......Vintage Air for one I know for sure.
"guruatbol" said:If I had the reputation for blowing up engines that the OP does
"silverblueBP" said:Thanks for the vote of confidence Mel :wth :nut
