crustycurmudgeon
I do have a later model filler neck with a metal "flapper" piece that I thought might work.
I went to the hardware store and got some 2 1/4" washers that are exactly the right size for this. The hole in the center is about the same size as the hole in the aforementioned later filler neck. My thought was to cut into the right and left sides of the filler neck leaving just a tiny bit uncut at the top and bottom, grind flats in two opposite sides of the washer, then slide the washer into the cuts, and weld. This should accomplish the vent/drainback feature that you put into yours, as there would be a tiny gap at the top and bottom after it's all welded in.
Whaddya think?
Frank
Whaddya think?
Frank
