drummingrocks
I've been working on a friend's '69 Mach 1 lately. The car came from the factory with the tachometer, so it has gagues instead of the usual idiot lights. Soon after buying the car, my friend mentioned that although the tach worked, the fuel gauge never read above 1/4 tank and that the temperature gauge never moved off the "cold" mark. Hoping for a simple fix, I manually grounded the fuel sending unit wire, and the gas gauge needle moved through its full range of motion. Secondly, I performed the same test with the temperature sending unit wire; the temperature gague needle also went through its full range of motion.
Attempting to troubleshoot the problem further, I:
1. Replaced the temperature sending unit twice--neither unit caused the gague needle to move.
2. Pulled the dash and instruments and checked the printed circuit--someone had run a hot wire directly from the constant voltage regulator to one of the studs on the back of the fuel gague.
3. Replaced the printed circuit with a new reproduction for a car equipped with a tach and gagues.
4. Replaced the constant voltage regulator.
At this point, the owner also requested that I install a new fuel tank. The tank came with a new sending unit, and before installing it, I hooked up the sending unit wire and moved the float on the new unit through its full range of motion. The fuel gauge worked perfectly, and was reading the fuel level correctly, even up to a completely full reading. Thinking that the problem was solved, I reassembled the dash, only to find that I'm still fighting the same problem. The tach works, but the temperature gauge stays on "cold," and the fuel gauge is stuck on 1/4 tank.
I can't understand how manually grounding each gague will cause the needles to move, but none of the gauges will read correctly when hooked up to their respective sending units. Any other ideas, or things that I might've overlooked?
